Circling The Drain
I did not replace the hose. The clamp on the radiator side looks like yours and was holding firm. The other end had the screw-down hose clamp and had backed off a good inch. The metal underneath was very shiny which is the only reason it caught my eye. I pushed it back in place and tightened it down as much as I dared and it stayed in place for my twenty-minute trip back. I feel like it's a ticking time bomb, though.
If you still have the original Top rad hose,they do expand and may want to "slide" with the ring clamps.
You could try for now to use two ring clamps to ensure it don't move.
I had a bulge in my original hose and was afraid of a gusher and overheating just looking at it.
51861[/ATTACH]"]
One day a new top hose and another factory clamp may be recommended.
I did not loose much coolant, jeep was cold and just dropped the rad side hose into a small coffee can.
Got maybe a 3/4 of a can out and then replaced the hose.
I only lost about a quart of Hoat or so in total.
that's a good suggestion to use two ring clamps for more friction.
It might help to also clean the radiator fitting and hose where it mates.
Circling The Drain
...One day a new top hose and another factory clamp may be recommended....
I'm thinking that is a good idea. It fits in my plan to update anything I can anyway. :)
EDIT: Just ordered the top hose. I'll do the bottom one next time I drain & flush.
The fitting itself was shiny as could be. I'd almost be tempted to give it a very light sanding to add a little more friction. The fact that the clamp has obviously been replaced at some point makes me smell a rat.
I do need to get the thing cleaned out real good, though.
ElCheapo
Erie PA
Ordered a new power steering pressure hose, and a front wheel bearing/hub, so I have something to do this weekend!
When was the last time you guys removed the air filter box?
Gosh I removed mine and went :Whoa: dead bug city, bees, moth, flys...kopkrab.gif
Maybe I need to screen in the front grille :icon_lol:
Anyways Since I had a spare new PCV valve, installed that today.
cplchris
Albany, NY
ordered the cv joints for the front driveshaft, they should be here tomorrow. brown santa has been bringing me a lot of goodies lately.
KJbell
Alabama
Today I installed a new CB radio. Used to have a Cobra 25 LTD Classic, but it was bought used, and it finally crapped out on me after about two years of use.
The new radio is a Midland and has the NOAA weather stations built in. It lacks a 9/19 switch and the stock mic is cheap, but for $45, I'm happy with the purchase. Considering buying an Astatic to replace the cheap mic.
Had rust growing, AC Clutch was Noisy! A bit of emery cloth in grooves &..
51872[/ATTACH]"]
Much better, a bit quieter as well.:happy107:
eyehatetofu
Buckeye, AZ
Finally paid off the heep today. It has been 14 years since I haven't had an auto payment. Hopefully the Jeep hangs around awhile. Now to save up a bit to buy a beater DD to relagate the Jeep to wheeling and hunting only. Really want to pick up another Grand Marquis / Crown Vic / Town Car.
Circling The Drain
Today I installed a new CB radio...The new radio is a Midland and has the NOAA weather stations built in. It lacks a 9/19 switch and the stock mic is cheap, but for $45, I'm happy with the purchase...
I have that exact one and it is decent, especially at that price. I hope you enjoy yours. :favorites13:
John3seventeen
WV Panhandle
John3:17 said:
First Valve cover in
Finished it up
Drove it without heat. Damn blend door is stuck good now. Yesterday a little heat today nothing. No hum from the motor. Looks like I'm about to get intimate with my dash. :favorites68:
At least it isn't too cold in the mornings these days. Anyone know if the dial/switch can fail? I'd like to rule out the little things before getting it all apart.
Geez what is this.... Painted spotless intake & TB's day?
I am jealous and envious all in the same moment.
That looks absolutely awesome John & Tom wow that is better than new, so polished!
Mine is dirty gross and runs like a bag of...well you know what I mean.
I noticed today my jeep has a bit of a stumble or shake going on at idle.
Then with the hood open, I could see the vacuum hoses vibrating.
Dang..what's up with my KJ?
I increased the rpm at the TB (2000 rpm) and I could still feel it. eek.
LibertyTC, This winter has been rough on mine, have a lot to do this spring to get it back into shape, complete undercarriage repaint, rock rails, rear bumper , engine is not too bad , needs a little work to get it back into shape Don't look at the wiring, redoing some of it to change some of my lights around.
^ After viewing that Pic, looks like I got a lot of work to do in the detail department, again.
Very nice Tom, what are you using on all the black plastic to make it look the shiny?
Or was it still wet..??
Luckily no salt this year on mine. I bet you got a lot of work ahead of washing/paint work to bring it up to your high standards. Hopefully no serious rust is forming on yours.
