burntkat
Minor 'oh shit' moment.... The new line doesn't look like the old...
Oh wait, what's that label on them mean... They came out of the same bag....
Ahh, we're good...
.. And in place. A little fiddly to get into place (don't join them til they are in-situ, makes it lots easier), but a hell of a lot better than shipping in an enormous box to avoid bending them for shipping.
Once they are in place, kind of massage them to clear and fit where needed. They won't fit the oem saddles as the OD of the line is much larger. Anti-chafe spiral wrap or (good quality aftermarket split loom) similar, with (screwed-in) zip tie saddles to brace the lines will help avoid work hardening and breach.
burntkat
While we are here, here's how I filter my power steering and transmission fluids..
MUST be on the return lines... Not rated for higher pressure otherwise....
Braced to the hard part of the HP hose because I'm kinda OCD about letting hoses flop around. Yes, I adapted to JIC/AN industrial fittings to make the power steering setup stouter (and easier/cheaper to repair in future). I do need to shorten that hose and put a 90 at the junction.... Or some hose protection. It's too close to the rad cap for comfort... But it's been like that for 5 years without a drop or chafe...
burntkat
Problem - High side R134 hose won't connect owing to the sensor being in the way....
Anyone have ideas...
burntkat
I checked and that sensor attached to a Schrader valve. So, remove the sensor, suck the system down, pause for leak down test. If passed, fill the system. Replace the sensor before run and all should be well, yes?
EDIT - yes. This worked a treat.
burntkat
Waiting on the leak down test (45 minutes) to complete.
20 minutes remain, doubt there will be issues.
One of the employees here brought his girlfriend and her Dachshund puppy to work. I got my share of puppy kisses for the week. I need a new dog.....
burntkat
All done. It's only 60 degrees out of her vents. Not sure why... But it beats the hell out of 120 ambient after my wife's been at work all day.
benibiker63
Hawaii
My ac went out yesterday while driving home from work and the humidity was up around 80%, temp was 85 so it felt like 96, it was miserable. So I quickly started trouble shooting to see what was up because the compressor was not engaging. I knew the freon was well serviced because about a year ago a leaking hose was replaced and it was cooling nicely the day before. I'll just say Google AI is amazing, it told me specifically what to check starting with the fuses and relay. It told me specific fuse numbers on the dash and relay location under the hood. The fuses were good and I swapped a nearby identical relay with the ac clutch one and still no go. I further followed Google AI that told me to check specific voltages at specific pins on the high and low pressure switches and at the clutch. There was no 12v present at the clutch with power on and the ac on. Following Google AI, it told me to jumper the clutch at the relay by removing it and jumping the terminal, the clutch engaged and the ac blew cold air; that was a good sign. AI told me to jumper the low pressure switch and the clutch did not engage. It told me NOT to jumper the high pressure switch because it's not a off-on type switch like the low pressure one. It has three pins, one has a constant 5v coming from the PCM, if I jumper it incorrectly I could fry the PCM so I stayed away from that. AI told me specifically what color wires to check and what the results should be on that harness. So everything was good, the only thing left was the high pressure switch, AI was 99% that was the problem after everything I checked to include what a appeared to be a dead high pressure switch, it should have had some resistance, not completely open like I was getting. So next came trying to find the switch and I can't believe the range in prices for that thing. Jeep wanted $250, NAPA $150, O'Reilly $60, and Amazon $24, that's nuts! I went with O'Reilly because I wanted it now and wasn't paying over $60 for that thing. I replaced the switch and it all worked as advertised. Ahhhh, cool air in my little blue dinosaur again.
seafish
A few years ago, on my 2005 CRD, the AC stopped working, and I was able to diagnose a damaged condensor as the only problem.
So while I was doing the timing chain, I also replaced the AC condensor and, since I had opened up the system, I also replaced the lines, drier and orifice as well, and then had it professionally refilled. The AC worked really well until just a couple days ago, but now the AC blows air only about 10°F cooler then ambient temperature at best.
NOT sure where to start this time… guess I'll try google AI, but also open to any ideas here?
benibiker63
Hawaii
If it’s just not as cold but still cool i would say to check the freon. With as many things as you changed, there could be a small leak and some leaked out. Have it reserviced and checked for proper pressure.
benibiker63
Hawaii
I did the spark pl
You can see nearly all the engine wire looms have disintegrated again. The replacement loom available from the auto parts stores just does not last in the heat of the engine bay. Does anyone know of a brand of wire looms that will last more than a year?
Just wondering, why's your ac compressor/clutch disconnected?
The AC isn't working so I disconnected the clutch so the Jeep wouldn’t keep trying to run the compressor. Don’t know if that is at all necessary but figured it couldn't hurt as a precaution.
rustydread777
Jeep had a rough intermittent idle. Took off the throttle valve, cleaned all the funk and idle air control valve and fixed a few hoses. Runs great when warmed up. I'm sure the iacv is going out.
Country2003KJ
I had a similar experience recently with my A/C clutch. The air was really cold and then one day it got warm and then it got cold again a few days later. I listened and it seemed the engne was louder and growling an and then I noticed the growling was from the A/C clutch. I figured whole new A/C system but when I checked the system I had ample 134A so I figured I would go with the least expensive option such as replace the clutch. I checked all options and the range was MOPAR clutch at $450 down to bearing replacement at $25. I opted for the direct from SANDEN clutch at $150. The box came in a MOPAR box. So, I could have gone MOPAR direct and overpaid by 3X but going direct to SANDEN I got the right price. Exact fit with no leftover parts and the air is freezer cold again.
On the old: The bearing was shot and the insulation on the magnet was boiling off. Little specks of the old bearing metal sprinkled off as I removed the old clutch.
burntkat
For my next trick.... Addressing this absolute shit show of a parking brake....
I mean to either bypass the clutch assembly in the handle entirely, or add electric parking calipers to the axle or transfer case.
CherokeeLiberty
Northern MN
I mean to either bypass the clutch assembly in the handle ebtirely, or add electric parking calipers to the axle or transfer case.
I addressed my cluster of a parking brake by pulling the shoes out of the driver’s side plate. The pawl rusted and seized solid, so it was useless. We’re on flat ground here, and I have a wheel chock under my driver’s seat just for fun.
burntkat
I live in the SC low country, so it's relatively flat here... But even so, the parking lot at work has some slope to it.
Besides, the underseat space is taken up by my pistol safe, and comms gear....
I want to finish my alarm/remote start install, but right now it's on hold as I have to keep the vehicle in gear to prevent it rolling away. Yes, the parking brake ***** THAT much.
I probably could imagineer some sort of bracket to mount around the shifter (manual transmission, BTW) that will throw a ground via an array of microswitches... But I'd rather spend that skull sweat on installing either a transfer case mounted parking brake, or electric parking calipers added to the rear axle housing. Distant third place would be to engineer out that asinine clutch in the lever. That's the dumbest thing I've seen since the old Pontiac Fiero emergency brake iteration.
Today I repaired some of my wiring for the heated seats, CB radio, and USB module for the head unit that are behind the center stack. Years ago I had used scotch locks to wire those in, and the connections were getting flakey. I replaced those with crimps, and no more issues.
The aftermarket heated seats have another issue that is probably in the electronics. The heating pads are fine but the controls are not. I’ll see what I can do to fix that before the weather turns cold this fall.
