What Bilsteins do I need
Scottybones
Clinton, CT
What is the actual part number for the shocks? The part numbers from the thread don't cross over to what I'm seeing. There's a 185859 and 185240. Thanks for the help guys. Looks like my Monomax shocks are lost so if that's the case then I'm canceling and getting the Bilsteins.
Scottybones
Clinton, CT
I think I figured it out. Should I go with the 5100 series or the B6? Placement is for the rear.
V8KLLA
Corpus Christi Texas
New guy here, currently shopping for pieces to lift my Liberty
I see the rear Bilsteins listed on the JBA site as "HD for 2.5" lift"...but no part #. Anyone have the actual part number for the shocks?
And the fronts are just stock replacement correct? No longer or anything? Part # for those??
Any and all help will be appreciated.
Thanks.
Scottybones
Clinton, CT
If you look up an 04 Dakota extended cab, that will be the correct size. I used KYB monomax so not sure What the number is. FYI, the KYB fits without the spacers
99-04 Dodge Dakota Extended cab 4x4 makes a difference
for the rear
dude1116
Pompton Plains, NJ
Question to go along with this thread: I could never find the Bilstein part numbers that JBA uses for his 2, 4, and 6" Bilstein shocks. Does anyone know these? The Bilstein shocks in the Amazon link posted above seem to be a different shock (with a different lower mount). The ones posted in the Amazon link are for a YJ it seems.
Some have used them as well if I remember right
jharrisliberty
Colorado
Has anyone figured out the model numbers for the 4" Bilistein shocks that fit our KJs? I am trying to shop around for them and I cant seem to find this information either. Thanks.
