ktmrider
I got a bare unit without mounts. Are the 2 housings different? I thought just the mounts were different and the housings were the same.
Guess I need to know if the housings are the same. If not can I use it as I have it installed or do I need different mounts or axles? Do I need to take it apart and put the gears and DTT in my old housing?
I had the local hot rod shop set the DTT. It looked like a new one but I did not install it. I'm thinking now I just did not get the axle pushed far enough into the diff. Did you see the pic..looks to far out to me.
That pic of the left side CV axle shows the problem - the axle isn't in far enough. Like Tom said in an earlier post, the large inner housing isn't supposed to be completely flush but it's close - yours is out about 1 1/2" or 2". Should be within a 1/4" or so to the differential.
It was the axle.
You back on the road/trail ?
