Washer pump
JIMMY JEEP
United Kingdom
Thanks Tony ,amazing how do you guys come up with pics of everything, no my washers are fine im going to purchase a device that heats the windscreen washer water and was wondering for the installation if the pump is inside or out ,apparently it will be easier to do with it outside. Just gotta find some room for the unit under the bonnet,pretty cramped in there, You wouldnt happen to know which wire is for the ignition apparently it takes a feed direct from battery but also needs to be wired through the ignition ,so it only has a supply when ignition is on.
