trans swap auto to man
jeepg
Bend OR.
I have a 07' lib. I was thinking of swaping to manual trans form auto ? has anyone done this ? is there a computer problem ?
George
twack
rochester mn
its really not that hard at all
you just sell your auto jeep and buy a manual jeep, swap done
jankerson
Raleigh, NC
That would be the easiest and cheapest way for sure.....
Don't know why anyone would want a manual anyway.......
Automatic is better for driving and wheeling..... :imo:
Had both over the years in different types of vehicles and a manual gets to be a pain in the neck depending on were most of ones driving is...
Only time I would even think about a manual is if I really liked the vehicle a lot and there was no other option other than a manual.
JeepCoMJ
SE WI
You would need a manual transmission compatible with your year plus sensors for your year on the trans (if connectors changed...IDK if they did)
Manual trans flywheel, pressure plate, clutch disc, master and slave cylinder, line, pilot bearing, throwout bearing
Complete engine/trans wiring harness
Manual trans PCM (engine computer)
Manual trans pedal assembly
Manual trans tunnel shifter boot plate, shifter boot
Manual trans ignition lock assembly
And more time than it's worth.
jankerson
Raleigh, NC
Likely will need a new rear drive shaft too.
jankerson
Raleigh, NC
New front shaft also and if you have the 242 select trac t-case that must go also as it does not work well behind a manual and why it was never offered behind a manual trans.
I was figuring that also, but wasn't sure what transfer case he has. :signs8:
JeepCoMJ
SE WI
242 works great behind an ax5 and ax15 in an xj, so I am not sure where you get that opinion
JeepCoMJ
SE WI
Yeah as long as you do not use the fulltime option it works,in fulltime it creates drivability issues with the clutch and why it was never offered behind a manual trans in the 1st place.
The action of the clutch being disengaged can create slip between input and output....if you shift slow as hell.
I used fulltime all the time in my xj with ax15. Never had an issue, not once.
