Town hates me sale/clear-out
rough location: NJ, 07922
PM me for address.
I'll be adding stuff as I find it.
Clearing out a bunch of crap here that I don't need.
Everything is free to whom ever picks them up, but I will take donations for beer money and pizza if you want. :D
KJ related:
OEM front/rear suspension (springs, dampers, UCAs) with 56,000 miles on them.
Other stuff:
I have a ton of early 90s dodge shadow parts (AP body mostly) i'm also ditching if anyone knows of anyone who wants it.
Otherwise i'm either hauling everything to scrapper in a couple weeks (early/mid october probably.)
righopper
Houston, 'Merica!
Kudos man. Just did the same. Held on to the old stuff too long here too, but only just cleared mine out the same. Then 2 weeks later a sagging Libby moved into the neighborhood. Oh well, they can rebuild from scratch.. [emoji50]
Sent from my SM-G950U using Tapatalk
I'd just move
never get rid of parts
Still have 55 Chevy parts boxed up from 1972
:happy175:
FOR SALE: 15'4"W 36'L 12'H SHED - $15000
Shed: Hunter Green
Roof: Dual Gray
Corner Trim: White
Fascia Trim: Hunter Green
Door: White
Trim Color (On Door): White
Trim (Around Door): White
Window Trim Color: White
15'4" x36 MaxiBarn w Duratemp T111 Siding
Pressure treated skids
2x4 floor joists 12in O.C.
5/8th ply-wood flooring
2x4 walls and trusses 16in O.C.
6ft 6in wall height
30 year architectural shingles
Upgraded 3 ft. single white prehung door with 9 lite glass - Right hand in swing (swinging towards the garage door); locate, as facing garage door from outside, on the right wall
Upgraded 10x7 Insulated SRP garage door with standard clear SP glass placed in the top garage door panel
10 ft. of Tread Plate
35 in. Insulated transom window with trim, 2 placed in each gable end, 4 total
Fiberglass insulated ceiling, lower walls
Rigid foam insulated upper walls
White Painted particle board walls
4' depth full width loft in back. 2x6 construction, 6 joists total, with plywood floor
$15,000
SHIPPING INCLUDED IF ARRANGED BEFORE SEPTEMBER 12TH AND ASKING PRICE IS MET.
FOCUSING ON WESTERN NJ AND EASTERN PA.
text/call @ nine oh ate two four to six zero seven six
-- John
All I can say is good luck
That sux for sure that you have to sell it
If you were closer I would look into buying it
Need another small building on the farm to store stuff , work on projects etc there
But again GOOD LUCK on selling it, nice building for sure
