fishin'liberty
sorry if there was thread on this already, but i couldnt find it. I was just curious on if you recommend doing OME coils, shocks, and struts or the OME/Rancho setup? Thanks for the info...
That is correct, just pulled my rear springs and Daystar spacers to replace them with OMEs, put one of the spring/spacer combos next to one of the OME springs and saw about a 1/4" difference between the two (OME was just slightly shorter).You get a minimum of 2" from the springs.
When I called AllJ's and explained what I had and what I wanted to do I was informed that I would need to use the OEM strut plates (which I still had). I have also ordered some Teraflex front bumpstops to help with any possible issues, plus I've got some JBA arms I'll be putting on the front when my back quits giving me fits...So i'm going for a similar set up, OME HD/rancho, for the front, since the rsx17505 ones are rated same as stock travel, do I need a different top plate (similar to daystar) if I use the OME spring or is the strut just going to sit at a higher, expanded height than it normally would with a stock spring?
