Auberon
Tonys suggestion of steel seems most appropriate, if you have a lathe with a faceplate, not much of a job really.
I do hope you don't mond the following comments:
Polymers:
There are some really ****-bang bearing polymers out there that are strong in tension, torsion and have a tremendous frictional hardiness.....it might be wise, with respect to steer away from the thermosetting polymers, due to their tendency to be a tad less durable. The problem with splitting might result from when the nuts are torqued up properly, the PP's will easily split...as they are not do not do well in resisting compression.
Machining:
You could go thicker but you would also need to counter bore for the nuts/washers back to a 3/8 inch thickness at the base. However, this may be truly flying by the seat of your pants and I'm not sure there would be much gain. Wud also need to machine a tolerance for spanner access, too, making as simple job much more difficult.
This would not be to hard to machine on the faceplate.
Question re tolerancing:
Just out of curiosity, as the numbers in are inches and quoted to 3 dec places how significant is the tolerancing in these numbers.
Thanks and Cheers to you all
Auberon
Polymers:
Machining:
Auberon
