Tire size help
JustinJackson
BC, Canada
Hey guys, sorry if this has been asked already but what tire size will I be able to fit without rubbing if I put a 2.5" lift in my 2004 renegade? Also would wheel spacers help to go bigger?
rjkj2005
US
245/75/16. Without​ trimming. 265/70/16 with some trimming. Same height between the two just the 265 is wider.
I run 265/70/16 on factory wheels no spacers with 3 inches of lift. I rub on the upper control arms towards full lock. Wheel spacers would solve that. But going for wheels to fix these issues this spring.
First what lift are you going with ?
You just can not give accurate answer with a statement of "2.5 lift"
So if its a actual OME lift at 2.5 inch lift then the answer above is more or less corect.
Spacer lift, you may be lucky and actually be able to run that size, but more than likely not.
Buy correct wheels if you want to run a 8 inch wide tread width tire
u2slow
BC
245/75R16 is a good starting point. Entry level truck size tire. Very minor rubbing that doesn't concern me.
I'm using a 1.25" spacer with stock wheels (summers) a 1.5" adapter with Wrangler wheels (winters).
