tire question--long trip
smarkham
Mt. Rainier MD--right by Wash DC
Hello
The other day I got a tire patched because it had nail in it. It had a slow air leak. Person who fixed it (car shop) said it was as good as new. Tire IS almost new. I'm going to be traveling from MD to TX for Christmas. Have any of you done a long trip with a patched tire?
If I had some more money I'd buy another one...but you know what it's like right now. Money is tight.
THANKS
PS It's been a week and the tire is...as good as new. No air leakage.
IF...the main word here, if it was done correctly then it should be fine. Also as long as the hole was not too big, small nail should be no problem
icarl
Peace Country
I once worked in a tire shop. For passenger tires they glue a patch over the hole. It works. I've had lots of tires repaired without problems. Don't worry. Be happy. :D
Atrus
Metro Detroit, MI
gluing the patch I'd have no worries. I don't care for the plugs, but I have had plenty of them and never had a problem.
I wouldn't worry too much.
icarl
Peace Country
It's been awhile but if i remember correctly this is how the patch is installed. First you find the leak(s) in the tire using a dunk tank filled with water. Remove any nails, etc. Next you take the tire off the rim and roughen the surface around the hole inside the tire with a special tool. Then you apply the glue all around the area you just roughened. Next you put on the patch with a special wheel tool that gets all the air out. Then you apply another layer of glue/gunk over top of the patch for extra protection. Finally, you put the tire back on.
I have had several tires plugged or patched in the past with no problems. I also carry a plug kit in my off-road bag. I plugged a tire once myself without even taking it off the vehicle because I was real lucky and found the nail. Then pumped it back up (I carry a pump too)
I am running on a plugged tire now. Patches are supposed to be better I think. Don't worry about it.
offroadohio
Roseville, Ohio
I work at a tire shop and I am RMA certified. The only patch accepted as correct these days is a combination patch. A combo patch works like your old glue patch, but it has a "plug" type thing on it aswell. you push the plug in from INSIDe the tire (instead of fromt he outside like strign plugs) The actual patch then glues, just as a normal patch would.
http://videos.howstuffworks.com/multivu/4691-tire-repair-safety-video.htm
04Liberty
MD
Hello
THANKS
TX to CT with a plug in a 275/55/20 on a Ram towing the Liberty on a flatbed. No problems.
Corwyyn
Southeast of disorder...
Done that myself a few times, in fact the tire on my tailgate right now has a plug in it because I managed to pick up a big-*** rivet in it the other night. But since I'm getting new BFGs tomorrow it's not a big deal. I've also plugged them on the vehicle like you did, actually easier for me to do it that way than to take the tire off since it doesn't move around on me :) If it is one of the new patches like offroadohio described (and it probably is) then I would have no problem running it on a road trip.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
I've done several road trips on several patched tires. (I've had bad tire luck) It's not a temporary fix, it's a permanent fix. You should be fine.
jnaut
Seattle
They got that newfangled stuff that doesn't patch, but 'plugs' the tires now, right? My understanding is the only disadvantage to that plug stuff is that because it doesn't 'cover' the hole like a patch does, there's a limit to the size of hole it will fix.
Corwyyn
Are you talking about the 'fix-a-flat' stuff? I'd only consider that as a last resort - since like Dave I carry a plug kit and a compressor in my Jeep I feel pretty good about being able to get a flat roadworthy again (as long as it's a smaller hole in the tread - sidewall? Time for the spare.)
J-Thompson
just south of doucheville
I have several patches and plugs on my F250 ,8500# + work truck
some with 30K on them and never a problem
I plugged a LARGE nail hole in my LTB's on my TJ my self with out removing the tire and it works fine
moparman
Baltimore, MD
I have 2 patches in my right front for a couple of months now, I do about 2,000 miles a month. I would use the "fix a flat" as a very last resort. If you like your tires, don't use it. I have never had it work 100% for me anyway. The goop makes a problem for the next person dismounting the tire and the propellant inside is probably highly flammable.
Marlon_JB2
Kombat Edition Jeep
Fix a Flat or Slime, whichever, they're all wastes of time. I wasted $20 on a Slime kit for my scooter, and I STILL had to buy a new tire. :(
moparman
Baltimore, MD
I have tried slime on my mountain bike, only to watch it ooze out of the spoke holes. What a rip off.
Same here.. I plugged two of my tires before I got my yoko's.. No problem at all if the person knows what their doing..
