Tire and Rim question
CMHKJ
Seattle, WA
Anyone have a pic for Goodyear Radials? P216/75R/16. Getting a lot of mixed results when trying to image search for them. Also if I were to get these, what Soft 8's would I need?
These?
Thanks for the input!
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Goodyear Radials?
Wait
The Goodyear Wrangler Radials?
STAY AWAY, THEY ARE JUNK. If you buy them, you will die in a fiery crash first time it rains.
Ry' N Jen
These?
You are NOT talking about the Goodyear Wrangler
GS-A are you? (See attached picture)
If you are...
Just like TBJ said, STAY AWAY FROM THOSE!
Those tire are just plain and simply CRAP!
I wouldn't even use one as a tire swing for my children!
The word "Traction" and "tire" for these is an oxymoron!
You can do way better!
ThunderbirdJunkie
Bronze Supporter
Newport, KY
If you think the Wrangler GS-A's and ST's are crap, you have not driven on the 1974-style Goodyear Wrangler Radials that Wally World sells.
It is PAINFUL.
To the op, look at the BFG AT, and the Kuhomo Road Venture AT. Those are better tires fro sure, and I'm pretty sure both come in the desired size. :)
And for the heck of it, GS-A= Get stuck anywhere (sorry, couldn't resist.)
incommando
SW Ohio
As to the rims you attached:
I would not run anything wider than a 7" rim with a 215 mm wide tire. The narrowest tire I would run on an 8" like you attached was a 245, and then I'd probably want an E-series or something with a sturdy sidewall.
Also, you need a 5x4.5 bolt pattern and not the 6x5.5 pictured.
Try these: http://www.summitracing.com/parts/CRR-3977712/
