Could I have? I changed out a failed water pump last weekend and while I had everything drained, decided to change out the hoses, the belt, new coolant (to replace the stuff puked out on the driveway...) and the thermostat, Stant 14369. As I got to start putting it all back together I realized that the new thermo didn't have a long piston like the OE and it had a plain gasket wrapped around it. The OE had a tab on the gasket that located it in the thermo housing and this one didn't so I located the new thermo and the air bleeder hole in it like the old one, but I agonized over whether to put it off and double check at the parts store. But I cross referenced it online with the Rock Auto part in the link above and decided to use it.
Everything back together and no leaks, burped and air bled the system, etc... My wife takes it out a couple of days later for a longer day long drive and yep, it started leaking, a few drops from the top radiator hose. Well, I think probably a poorly located clamp and so I fussed with it a bit and added a second hose clamp to make sure. Warmed her up and no leak, BUT... it suddenly occurred to me, COULD I have put the new thermo in backwards in a blonde moment (without the tab on the OE gasket one could reverse it...)? Would that have caused the leak at the top hose because it built enough pressure to just leak from the weakest point? Thing is, its not overheating or running warm. The needle stops at the midway point of the gauge where it always pointed fully warmed up. But the bottom radiator hose NEVER warms up. Would that be normal as the radiator is supposed to be returning cool coolant to the engine? Or am I sitting in a time bomb waiting for a pressure leak somewhere else?
If the thermo were in backwards wouldn't it cause the engine to overheat? But shouldn't the bottom hose be at least warm? Help save me from myself and save me the PITA from draining the radiator tomorrow and pulling the hose and housing to check... 2003 with the 3.7 BTW...
