The BatCar
klc
“It flies like a truck.”
PNW
My turn to be the noob, lol.
klc
PNW
We’ve all been there! :)
I should probably mention that wherever I go, I turn out to be the weird guy.:D I’m neither your typical automotive nor off-road enthusiast. I’m a Geek. It’s been almost twenty years since I had to move on from the Bug, and I’m curious about geeking on a big machine again. There’s also thousands of miles of National Forest roads within a two-hour radius to explore, and some dunes, even.
Just hangin' out.
Heck, Liberty cheaper to wrench on than Bugs right now anyway. Been waiting on the front wiring harness and chopped front end for over a year now.
  • Wow
Reactions: klc
klc
PNW
I installed the BatHooks today. It took about three and a half hours as I slowly worked my way through. The service manual is a little vague on some of this, for instance it didn’t mention the side marker lights. Also had a bit of trouble locating the down below screws, they were further back than I realized. But the work is done, and no blood was shed.
Just hangin' out.
No blood sacrifice to the machine gods!?!?
Oh no.
  • Haha
Reactions: klc
klc
PNW
Soooooooo………
I knew my spare tire was old, but I didn’t realize it was ‘Manufactured in 2000’ old. I’m getting it replaced today so I’ll have five matching tires. Once I removed it from the back I found this:
klc
PNW
I think you can flip that part if you have to fit a little larger tire. Maybe.
Okay, cool. I don’t think anyone’s had big tires on it though. Rim size shouldn’t make any difference, right?
But Holy Dry Rot, Batman, I’m lucky I never had to put it on the ground. Then I’d have two flat tires.
klc
PNW
I’m trying these out today. They’re sold as 3157’s but I decided to put them in the stern ports to see what happens. I did have to flip the first one to get it to illuminate. I half expect these to morph into some sort of Ray Harryhausen mechanical locust critter.
I’ve gotten into the habit of backing into my driveway, and there’s a window that lets me check all the lamps in my rear view. Everything I’ve bought is working fine so far. If these behave I’ll get another pair for the bow next month.
Brake lights
High mount brake light
Reverse lights
License plate and reading lamps
Courtesy lamps
Side markers
Rear dome lamps
Just hangin' out.
Soooooooo………
That's just the rollover indicator in case you aren't sure if the Liberty is on its roof.
klc
PNW
Now I have some pictures out of the old camera. I went along Highway 31, the Oregon Outback Scenic Byway and made my way to Alturas, CA for the night. A good fifty miles off pavement, I saw as many Pronghorns as vehicles while out in the bush. Then I circled around to Klamath Falls before heading for home. Near Fort Rock on open range.
klc
PNW
Little Sandy Butte turned out to be a volcano. On one of the roads to Lava Beds National Monument. First technical ascent and descent with the BatCar.
