Stuck front rotors
OldJoe
Gurnee, IL
Hi. I have a ’04 Liberty and a new set of Rock Auto Ceramic pads and rotors in a box. I’m having a hell of a time getting the old rotors off. I’ve used WD-40 penetrating oil, dead blow hammer, 2 lb. sledge, and even tried bolts through the caliper mounting bracket holes. Went through all this a couple of weeks ago. Nothing worked. I thought maybe if I waited awhile, the oil would work in. Went through all of this again yesterday and still nothing. Oh yeah, I double and triple checked that the assembly line clips that keep the rotor on during assembly are taken off. The rotors and pads on there now are OK, I just want to upgrade. HELP!
mine took some substantial pounding with a 5# sledge from the back side to get them off.
TheBlueKJ
South Jersey
This might sound like a duh thing but did you take the retaining clips off the studs?
CzarKJ
Townsend, MA
It's called a BFH for a reason, right Tim? :happy175::happy175:
The number of things my BFH has "fixed" on my Lady is ridiculous. Also just rescued a pretty stout cheater pipe that was going in the trash to go along with it!
Just for the record WD40 doesn't do much of anything on rusted / frozen parts . Aero-Kroil or there are some other good penetrating fluids designed for this purpose
Kroil
creeps into millionth of an inch spaces, dissolves rust,
lubricates and quickly loosens frozen metal parts,
frees rusted bolts, frees frozen shafts ...
about the best stuff I have used
Now get a BFH and go after it like you really mean it, get tough!!!:happy175:
CactusJacked
Chicago Suburbs
I'll have to get some of that Kroil penetrating oil, I usually use PB Blaster. Has anybody tried the home brew using 50/50 ATF and acetone? Machinist Workshop Magazine did a controlled test on some of the commercial penetrating oils, and the Kano Kroil came out on top. Except for the ATF/acetone, which performed twice as good as Kroil.
OldJoe
Gurnee, IL
Kroil
tommudd... I wasn't using regular WD-40. They have WD-40 Penetrant Spray that I used on a few non-automotive stuck bolts and plumbing and had pretty good luck. Anyway, I'll give Aero-Kroil a try as soon as I locate a dealer. Thanks for the tip. Joe
Darn Rights!!
50895[/ATTACH]"]
Now That's What I'm Talking about! :icon_lol:
