Rescu2000
Ok guys, I don't know if anyone has tried this, but I'm going to try to install an 8" or 10" Solobaric (square) sub under the front seats. I realize that there is a 6.5" available, but that isn't enough. I've taken some preliminary measurements and I think I can get the 0.66 cu ft required for a 10" Solobaric. However, that is a minimum. I'm going to begin with the maximum size box (0.66 cu ft) but I'm going to put an 8" sub in there and see how that sounds. I may build one 10" and one 8" and compare them. I can always cut the 8" hole out bigger, or resurface the box and cut another 8" hole if I decide to go with the 8's. I plan on having two subs up there.
I'm going to form the box out of fiberglass. This will allow me to utilize the maximum amount airspace out of the room under the seat. I'll try to make the box removable, but the only way to remove it will be to pull the seat out (probably). This will help with theft issues also.
If I can pull this off, would anyone else be interested in a box like this? It'll be a pain to install (pulling the seat). It would not work in a unit with power seats. It should get really loud though. Especially if I am able to port it. (8" only, the 10" couldn't be ported, box wouldn't be big enough)
My next step is to pull the seat and get some exact measurements. I'm sort of hoping I'll find a way to build it out of wood instead of fiberglass, much easier.
I'll keep you guys posted.
Rescu2000
Rescu2000
