Starting problem first thing
whosthedaddy07
UK
Hi ALL... new member (Jeep Cherokee 2005 2.8crd Renagade owner :) .... I've been having a starting problem first thing in a morning for months now, had all the glow plugs replaced still the same problem, but it starts fine for the rest of the day once its started , Had a new powerful battery and still the same, new fuel filter recommended by my local dealer still the same so yesterday i decided to do a test got one of the old glow plug id still got which i new worked put it into number 1 glow plug wire rail then rested it on the engine turned the ignition on the glow plugs worked fine, Then started the jeep and the glow plugged worked for pre heat and post heat as it should do , with everything connected back up this morning it still turned over for 10+ seconds then fired up with a puff of white smoke ,then starts first turn of the key for rest of the day, its seems like its got no fuel there when left over night any ideas guys or tests i could do ...... Many thanks in advance
BjBnet
Ottawa, Ontario, Canada
I think your guess about the no fuel thing is right. I don't know about vehicles much but if you have a bad primer bulb for your outboard you get the same problem lol I know, I'm not much help.
Billwill
White River, South Africa
Try posting this in the CRD section here...more chance of getting a response!
Otherwise lostjeeps.com has a very good CRD section with lots of experts regarding the diesels!
ridenby
Gold Supporter
Kentucky
Probably the fuel supply pump. Lot of CRD's add a Cummins pump at the fuel tank. Will find details at Lostjeeps.com
