ThunderbirdJunkie
Bronze Supporter
yeah, but it's annoying when some ******* screws up your perfectly good 140,000 mile lugnuts.
One big mis-conception is that removing a lugnut can make it strip,totally false(I know it does not apply to the OP),it was crossthreaded when put on last.
Now Have I broken wheels studs before? Yep but only taking them off from other idiots crossthreading them before me.I use my IR Titanium impact to remove lugnuts,it's always on the lowest setting which is about 400lbs-ft of torque.I always start every lugnut by hand and at least 5-6 threads and zip them the rest of the way on with my Snapon cordless electric impact.With a fresh battery and my flip socket my electric impact will only tighten them to 80lbs-ft unless I rap on them for over 5 seconds,verified on a test machine,and most vehicles have at least a 80lbs-ft lugnut torque.Then I lower the vehicle and use a calibrated Snapon torque wrench set at the OEM specified torque for the vehicle.Then they all get re-torqued by another person.The last 2 steps are company policy and must have 2 sign-offs for wheel torque.
Never had a issue yet.
^^I torque mine to 100 with a 1/2" torque wrench. Now I will have to look it up when I get home to double check if I am doing it right.
Mine get's torque to 150lbs-ft,but that's with a 6" extension(10" wide rims) and I ain't running OEM stuff for lugnuts and wheel studs.My Haynes states between 80-110 ft-lbs, what is every one here torquing them at?
Normal for Ford pickups,even 1/2 tons.jeez.. that is more than the biggest Ram truck requirement.
jeez.. that is more ft-lbs than the biggest Ram truck requirement.
A Ferrari Enzo requires it's 4 lugnuts(one per wheel) to be torqued to 485.5lbs-ft.Ya that was in the day when it was a 2 person job one to hold the socket on and the other to sit on the extension bar to torque it..!!
