TypeRx
Hey all - I've been doing a lot of routine maintenance in my Jeep lately (03 KJ Limited with 170k miles) with the hopes of getting another solid 10k miles out if it before moving on. It runs amazingly well. However, I do have a nagging oil leak (not enough to require more oil during normal OCI).
I have recently replaced both valve cover gaskets and thoroughly degreased the engine bay. I will swap in a new oil pressure sensor as mine is original and based on the block area immediately surrounding it, is slowly leaking. But, I have a separate leak, I believe, that is more towards the back of the engine bay. When idling I get a bit of smoke from the driver's side cat from oil dripping on it. The area near the oil pan just adjacent to the front driveshaft head (front part) has some oil on it. The oil pan itself does appears fine. Would this be indicative of a rear main seal leak?
It isn't a big issue at all - I just hate leaving drops of oil on the driveway and the smoking at idle.
Any ideas?
Any ideas?
