- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 43
So 6+ months? I'd say normal for the most part if the pressure cap was messed up.Any cooling pressure test kit will come with the adapter to test our caps.
Your engine is a big air compressor and will produce and expel water and water vapor out the tail pipe,more noticeable 1st startup in the morning.H2O is part of the emissions coming out of the tail pipe also.I think so. Definitely a few months.
d'oh! I didn't think to test the cap.....
bah.... i've returned the loaner tool.
x.x
so I noticed some water that came out of the tail pipe at start up later today after everything was buttoned up. No white smoke.
I didn't feel and smell like coolant. condensation??
It hasn't rained down here at all for a while.
Is this a sign of a HG issue?
Yeah I'd say your whole issue was that cap from looking at that pic.here's a picture of the old rad. cap.
Arrows point to the two cracks.
Thanks a lot for the note. If there's a coolant leak, then one current sample should be enough to tell you whether the coolant is getting into the oil. Note: we like to see samples with at least about 1,000 miles on them, if possible. If you send a sample on a very short interval, then maybe coolant wouldn't have had time to accumulate enough to show up in our tests.
Nice that they only require one! Guess they can compare to averages.
Hey everybody, sorry to butt in but this seemed like the most appropriate thread.
I recently have identified what was a very slow leak from a very shoddy coolant reservoir cap, and replaced it.
Within a day or two of replacing the cap I come out to find a coolant leak along the bottom of the front bumper, and an empty reservoir. upon under hood inspection I couldn't find much of a mess that may indicate a leaky hose or water pump failure. the bulk of the coolant I found under the hood is located on the driver side near the headlight and side of the radiator, with virtually no overspray back towards the power steering pump or battery.
Is there the potential I have a cracked radiator, and putting the new cap on allowed it to build enough pressure to force more coolant out of the crack? and if so is there any definitive method to test for the source of the leak.
Any help would be greatly appreciated, Thanks all and Happy Thanksgiving
