center of wheel to fender, is it normal for driver side front and rear to be a little lower than passenger side ? how to correct it ?
Common issue but I always set the drivers side up about 1/8 to 1/4 inch when doing a lift
It is a good idea when installing all the usual lift parts, springs, top plates, extra isolators, etc., to perhaps use the clevis lift to adjust and fine tune, level out the front to the rear?
What if it is the rear that needed to be adjusted up or down 1/8"-1/4"?
Plywood? It's one thing to worry about rust, but termites?... :happy175:
