Shifting FT > PT
rchung813
New York
I have a simple question which may have been answered. I know you can shift on the fly from 2WD to PT or FT, however can I shift on the fly from FT to PT or 2WD? :-s
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
Yup, Yup and Yup. \:D/
thecause17
North Huntingdon, PA
FrenchCamp49er said:
I've searched and searched; Whats the best way to shift out of 4LO ?
Owners manual should say, but you should slow down to 2-3mph, shift the transmision to neutral (if you have an automatic, depress the clutch if you have manual). While the vehicle is coasting 2-3mph shift into 4LO, the same to go back out of 4LO. Don't pause the transfer case lever in the neutral position while doing this, it can cause some grinding.
hyde
I normally just stop and switch to N and then engage 4lo. It works fine. If it doesn't switch I do R back to D then to N then switch. it works fine that way
Marlon_JB2
Kombat Edition Jeep
That's what I do. It works well.
2003KJ
It can also cause the safety feature thats built in on the tcase to engage and make it hard to get it out of neutral. This safety feature is besically once you're in a particular setting, it takes a bit of effort to get it out....kinda like preventing you from accidentally knocking it out of a particular setting.
