Yup, Yup and Yup. \rchung813 said:I have a simple question which may have been answered. I know you can shift on the fly from 2WD to PT or FT, however can I shift on the fly from FT to PT or 2WD? :-s
FrenchCamp49er said:I've searched and searched; Whats the best way to shift out of 4LO ?
That's what I do. It works well.hyedipin said:I normally just stop and switch to N and then engage 4lo. It works fine. If it doesn't switch I do R back to D then to N then switch. it works fine that way
thecause17 said:FrenchCamp49er said:I've searched and searched; Whats the best way to shift out of 4LO ?
Owners manual should say, but you should slow down to 2-3mph, shift the transmision to neutral (if you have an automatic, depress the clutch if you have manual). While the vehicle is coasting 2-3mph shift into 4LO, the same to go back out of 4LO. Don't pause the transfer case lever in the neutral position while doing this, it can cause some grinding.
