Lots of different advise...
I like to take a conservative approach to something like this... a little time spent now, may save a bigger hassle later.
My boat sat for several years, hadn't been planned that way, but such is life... After draining and refilling with oil, I pulled the plugs and gave each cylinder a small shot of Marvel Mystery Oil. I let it set over night and before replacing the plugs, I turned the motor over, first by using a socket and bar on the crank pulley (motor was free) then by spinning it over until I could see oil coming up into the valve train.
I replaced the plugs, started the motor and ran it a low RPM until it'd warmed and the smoke from the oil in the cylinders started to lessen.
I increased the revs incrementally, essentially as if I was breaking the motor in. It gives the rings a chance to loosen over time and cleans the bores of any tiny bit of corrosion that may have formed.
I took it through about 4 complete heat cycles, then changed the oil and filter... it looked filthy. After about 10 hours of running, I changed out the oil and filter again... much cleaner this time.
Since then, just regular maintenance... it's been several seasons and the motor runs great. What I did was probably overkill for your situation, but perhaps there were a couple of ideas in there that might help out.
