ThunderbirdJunkie
Bronze Supporter
Thought there was a bolt for said panel inside the access panel?
have not been in there in forever though
There's a square access panel on the tailgate panel. After that it should be self-explanitory
I had the same problem with my KJ so I pulled off the tailgate cover so I could get a better look at the locking mechanism.
When you're looking at the locking mechanism from inside the tailgate cover side you will see 2 wiring plugs attached. The one on the left only controls the letting go of the liftglass.
The one on the right plugs directly into the microswitch/sensor that is causing the interior lights to stay on and glass open to display on the dash. Disconnect the plug and underneath where you disconnected it you will see a T15 screw holding the microswitch/sensor to the whole locking mechanism. Undo the screw and you can now replace the microswitch.
I only disabled my switch for the moment by removing the little blue rubber knob which was already half hanging off.
