So the knock is all but gone and replaced by this kinda rattle that seems to be getting worse. Again only heard on rough road seems to be under the front left seat location wise. Cv on the property shaft maybe?? It's there in 2wd and fulltine .
Sent from my SM-G930F using Tapatalk
So I have checked out the prop shaft there is quite alot of free play in the shaft prob at least 3/4 of an inch whether that is in the transfer or the cv not sure. It does also make a rattle and a metallic ding when moved . New cv on order
Yep they have the sleeve they are all tight this was one of the 1st things I checked. Shocks have only done about 5000 km
Thank you, first I wanted to know if is that noise, then I will do other side.If you are doing one, do both the other side will be just as bad & they are all that aligns the rear axle.
