Rear creeking noise
ShafferNY
Ticonderoga, NY
I have this noise that started this past fall. Whenever the temperature drops below 30* there is a creeking sound coming from the rear end. It only happens when the rear axle flexes or you hit a speed bump or something like that.
I've been lazy about looking at up until now. I'm thinking it's probably coming from the rear sway bar. Any ideas what it could be?
I get it too but only when it flexes real good. When I do my oil changes and I am under there on a creeper anyway, one of the things I do is lube everything I can that moves like sway bar bushings etc. I use "Endura" by Castle It is a spray penetrating lube that stays put better than some of the other sprays. One of the reasons it takes me longer to do an oil change than most other people.
KJ04
Grafton, Ohio
Buy a can of silicone spray and spray ALL of your rubber bushings real good.
Check the glass that pops open in the cargo area. The seal that seals it is a very hard plastic. Cover it in silicone grease and see if it goes away.
Put some grease on that adjustment for the gate too. Its that little black metal piece that lines the door up with the latch when you close it.
ShafferNY
Ticonderoga, NY
It definitely sounds like the suspension. I'll try spraying everything. I have some silicone spray in the closet.
Thanks guys.
BTW, Bought another KJ today. :D 2006 Sport. The girlfriends new ride. She's one of us now. lol
drawnon
Bristol, CT USA
i have the same issue. i wondered if my shocks were going bad. i bought my 03 this june, so this is the first cold weather ive had it in. about half way through my 20 min drive to work in the morning it shuts up.
The noise can not be the rear awaybar since it has no bushings at all and is only bolted directly to the 2 LCA's.
DO NOT SPRAY the bushings with anything,it will only cause damage,they are designed to operate completely dry.
You have got rust build up and that is making the noise.Your location(using salt) and the lack of proper washing is causing your noise.My KJ has never had any type of sqeak or noise from the suspension,never sprayed my bushings with anything but high pressure water and my KJ is almost 7 years old.
ShafferNY
Ticonderoga, NY
Same here. It goes away after a while.
ShafferNY
Ticonderoga, NY
OT But...The newest addition to the family.
ShafferNY
Ticonderoga, NY
Taking what TJKJ said into consideration, I got under my Jeep and took a look around. The springs are not rusted at all. They all have the factory coating still in tact and look good.
Could this simply be from worn out factory shocks and struts?
Bad rear shocks,worn LCA bushings,or a bad tri-link balljoint is most likey to blame.
DeluXXXe
I have a 2007 Liberty with 18k miles and have same problem. Cant imagine there's rust anywhere... still Ill take a look.
ShafferNY
Ticonderoga, NY
Since we had our first big snow fall it's stopped doing it. I'm thinking the rear bushings were dry or something.
The '06 we purchased seems to do it too, only not as much.
Perhaps it's a 'Jeep thing'
if you didn't see anything ...then its a Jeep things run it until something falls off , then you know what to replace
LOL........yea, that's a jeep thing.........They shoulda just put that one sentence in the FSM and saved a lot of worthless printing.........haha...
I like that......:D
feetwet
Maple Grove, MN
My '06 with 19k creaks in the front and rear now that it is cold out here in Minneapolis... Any consensus if this is shocks or sway bar?
Should I get this checked under warranty while I still have it?
feetwet
Maple Grove, MN
feetwet
Maple Grove, MN
to the above 3 posts at 4:11/ 5:18 and 5:33 :eek::eek: more than likely its the front sway bar bushings, nothing really to worry about and it will come and go. with only 19000 miles the springs and shocks you have at least another 10 to 15000 miles left on them;)
