Prev Owner installed fog lights, OEM fog lights not working.
I removed the newly installed fog lights because of the crude install! there was no relay. they just forced a wire with a fuse terminal into the fuse panel along with a cheap switch and ground.
The relay for OEM fog lights is missing from the fuse panel. not sure its thats the correct location for the OEM fog light relay.
I still have to look under the dash to see what was messed up if anything.
any suggestions on what to check for in the Fog light circuit??
thanks
thanks
