J-Thompson
Not sure what you are trying to simplify there. I fully grasp the concept of how gearing helps the engine. It changes RPMs which in turns puts it in a different part of the power curve. It also gives a mechanical advantage which is why a the old trucks and jeeps with 75 HP motors came stock with 5.13 gearing. What I was including for the original poster and what you don't seem to understand...is that along with gearing there is other things he can do to help with MPG. The width and weight of the tire will affect MPG, sorry but that is a fact. If he want's taller tires he can go taller but keep them skinny. A 235/85R16 would be tall skinny and give better MPG then a 265/70R16. Also less aggressive tread would help. An A/T vs. an M/T, never said that regearing was worthless....just that there are other things that contribute to lose of MPG.
roughly 80% of your loss due to tires is due to hight
if not then by your reasoning if I could find a 40" tall 9" wide tire that weighed 50# I would not need to regear
oh and for the proof
LTB's ,31 X 11.5 ,measured OD of right at 31"
weighed them on a certified scale ,that I serviced, at about 55#
I thought they were heavier
when I switched to the MTR-K'sI lost about 1-2 MPG
32 X 11.5
same weight ,same width ,less tread ,more air
measured 2" taller
go figure?????????????????
what I figured
my Loss was all OD because I gained some on tread and PSI
