a.graham52
Like the title says, poor heat. If I operate the blower on the lowest speed then heat is pretty good. If I crank up the speed, the heat gets much cooler. Engine temp is consistently 190-200 and I flushed the core tonight. Water moved pretty freely in both directions. Also tried recalibration door with no luck.
Anything else I should be checking?
