MoladoGuy
PCV Valve: What is It?
Well some time ago I busted the plastic air tube connecting to the air box. I busted it right at the T portion and was unable to replace it. I just went to the dealership and bought a whole new PCV setup to replace my broken one. I am wondering if this is why I may have seen some nasty gas mileage. The gas mileage has been lowered by over 1MPG, all occurring after the PCV setup was damaged. Could the busted tube be the reason? I looked up what the PCV does and apparently it:
I am assuming it also mixes the correct gases and removes air pressure or something. Anyways maybe I will see a little more return in my gas mileage.
The PCV valve on the other hand or Positive Crankcase Ventilation system functions as the old "dump tube" which removes combustion gases and vapors that may get stuck in the piston rings and crankcase that can cause rust, corrosion and bogs
