long_tall_texan
Well, I have read a lot of questions/concerns about the stiffness of the ride of the OME 927 HD springs. So, I did a little scientific testing of my own. My Palm Pre has an app that can use the internal accelerometer to log vibrations, like a seismograph. So before I took off my Daystar lift, I logged a couple of runs through some parking lots with various sized speed bumps. I figured that would be a good comparison between the two. I then re-logged the same routes once I had my OME 927's installed.
Daystar Setup:
OEM Springs
Rancho RSX 17505 Shocks
Daystar 2.5" Spacer Lift
3/8" top spacer plate
3 Ring Clevis
OME Setup:
OME 927 Springs
Bilstein BE5-D916 Shocks
Daystar Top Plate
1/2" DIY Frankie Spacer
Looks like OME is a smoother ride - In all 4 tests.
Y-Axis shows G's measured by the accelerometer.
Daystar Setup:
OEM Springs
3 Ring Clevis
OME Setup:
OME 927 Springs
Daystar Top Plate
