Oil Light?
desertkj
Arizona
OK, when I pulled into my parking spot at school, I noticed that my oil can indicator light had just come on. When I turned it off and back on, the light was gone. I let it run for a little bit to make sure it wouldnt come on and it never did. When I got home, I checked the oil and its perfect. Any ideas?
2003KJ
Check for damage on the oil pressure sensor...should be right around the filter if I remember correctly.
Yea, usually if the light comes on, its just a bad sensor. Dont take it to likely though, the light does have a purpose. O:) Sometimes.. \:D/
desertkj
Arizona
Dropped it off at the dealer on the way home today. He said although theres a possibility of it being an oil pump, more than likely it's an oil send sensor (I think he called it). The light came on everytime I stopped and would turn off once I got going.
indieaz
Tucson, AZ
Oil pressure sending unit is the name of the part - it's simply the sensor that measures oil pressure. The odds of having an oil pump go out are astronomically low. On these vehicles the sending unit is a simple swap (unlike my vette which requires intake manifold removal #-o ). I'd swap the part myself.
desertkj
Arizona
It got done already. It says on the dealer invoice that it was registering 0 PSI oil pressure at idle and with the new part its 77 PSI!
2003KJ
ummmm 77PSI at idle is WAY too high....
You shouldn't even hit 77 driving down the road....
Cableguy
Flori-duh
Maybe the tech meant 7.7 and forgot the decimal...
That seems kinda low though. hmm. let me check...
the 02 manual for a 3.7 says 4psi minimum at idle, and 25-80psi @ 3000rpm
2003KJ
wow...maybe it's just me put 4 seems REALLY low and 80 seems REALLY high...
indieaz
Tucson, AZ
Well, this doesn't apply 100% to stock engines. But for a built V-8 engine the rule of thumb is at least 10psi per 1,000 RPMs. On cold startup though i wuld expect somewhere around 40-50psi @ idle. That should quickly drop to around 20-30psi when warmed up at idle. Probably around 30-50 when cruising.
Depending on what oil etc. you are using i suppose it could be possible that withint he first 30 seconds of startup whent he engine idles relatively high (around 1,200 rpms) 77 psi would be possible.
7 PSI at idle on oen of our 3.7s would be considered unacceptable to me and would indicate a problem with the engine.
2003KJ
That is EXACTLY what I was thinking....
Cableguy
Flori-duh
Apparently, DC Engineers think differently. \:D/
You may think it's a problem, but the people who designed the motor don't. I'll agree that initial pressure will be higher than 4, but once it warms up (like the book says to do) it really dosen't take much to push some oil around at idle.
IMHO anyways, not trying to argue.
