oil change & flushing --BOGUS?
eko
kenwood, ca
See akof notes in genl discussion: 4lo ****** linkage problem..
(2002 liberty sport 4wd) --- after 60 k miles of trouble-free driving & all scheduled maintenance, --- today a jiffy lube did 3k oil change & "flush"??? --w/ new air filter --- & now my jeep is needing to be towed --...
is oil flushing totally bogus? :-k
If you get a flush at a jiffy lube, then yes, its bogus. 8-[
They probably used used old oil to flush it out. That always cleans her out good. ](*,)
jimheem
East Hampton, CT
Is this the same Jeep as akof posted about?
If so, no matter how cruddy the oil the flushed your engine out with, it's not going to cause the transfer case linkage to break.
eko
kenwood, ca
yes -- same liberty --- now he's wtg for tow to nearest dealer
--- is it possible that a friendly push into 2-3mph movement forward may allow 4lo gear box to shift into neutral? 8-[
myjeepwalks
I wouldn't let jiffy lube vacuum out my car let alone work on it! Just my opinion though. :-#
Havoline
Southern Indiana
Just what, pray tell, is a "flush"? I've been diddling around with cars and trucks for a whole bunch more years than Jiffy Lube has been in business, and the only time I recall anyone doing anything like "flushing" an engine was one time when my Dad bought an old truck which had not been run for years and the engine was "seized". We spent quite a bit of time giving it #1 fuel oil enemas until it loosened up. Other than a situation such as that, I can't imagine any reason to do anything more than changing the oil and filter. (And I wouldn't even let Jiffy Lube do that!) [-(
I agree............Just stay away from Jiffy Lube.
bgjeep
I got a flush from some other place, they said is was some additive that cleaned out the old oil. a couple days later my camshaft positon sensor took a crap....not sure it it was related...but i was not happy having the KJ towed to the dealership.
