Nasty MAP/Boost sensor
Lara81
Vancouver island
So I cleaned the map/boost sensor, which had MASSIVE amounts of soot (no oil) on it. It turned out ok, after cleaning it, but I am going to replace it anyway cause it didn't come as clean as it likely should. I plan to go the SEGR route eventually but is there anything else that should be cleaned due to the large amount of soot found on the sensor?
CRD Joe
Cle Elum, Washington
Simply disconnect your EGR. Its called the ORM. Offroad mod. I cleaned mine then disconnected it and it has stayed clean since.
Lara81
Vancouver island
My concern is that I want to know of any other issues before they are huge problems. The EGR definately needs to go... it's now a matter of deciding which option is better SEGR or disconnecting and investing in some type of code reader if the CEL will always be on.
