Dimebag
Hi guys sorry to say I have some more heating questions!!! I recently replaced the fan realy behind the glovebox and put in a new thermostat-Advance Autos best one, and the damn Jeep still is running cold. I filled the radiator after changing the thermostat (removed the top hose and filled the rad and topped off the block) filled the overflow just in case and since it's gotten really cold outside the block just does not want to warm up while on the highway. Around the city it takes a bit, but will warm up and blow pretty warm inside the cabin, almost get good and hot like the old days when it was new, but if I hit the highway it stays on the cold side of the temp gauge forever and almost never comes to temp....
I have replaced the following:
New aftermarket radiator
New thermostat I believe its a Stant 195
New fan relay
New anti freeze (green old fashioned 50/50 mix)
Also I went to check the overflow this morning after a chilly drive home from work, thinking it might be low and it had no pressure when I opened the cap!! Yes it was secure, yes the motor was finally to operating temp and blowing out hot air in the cabin. But I thought it was odd that it didn't have any pressure when I released the cap.....possible bad rad cap???? Bad thermostat??? I am out of ideas and really fed up with playing with this poorly designed system, and any good ideas would really come in handy!!!! Also no I have never flushed the block, but with swapping the rad and thermostat twice, I have changed out all the anti freeze and it's a nice green color.
Please help tired of freezing my **** off!!!! And thanks!!
New fan relay
