Lifted alignment specs question
Aceofspades
Buffalo
Figured I would start a new thread. I have a lifetime alignment agreement with firestone
My specs are out again and the tech asked if I should set it to OEM or specs for the lift kit - see sig
I searched and couldn't find any info to relay to the tech doing to the work so I'll shoot for OEM today and later down the road if there is a another set of parameters that it needs to be adjusted to
Thanks
Thanks
Camber and toe = OE spec
Caster anywhere from 2 degrees to 3.5 degrees and no more then 0.5 degrees cross caster.
Aceofspades
Buffalo
Perfect. Looks like the lifetime alignment is going to play out well.
A few trail rides and it's out of spec already.
The final specs today are spot-on to what you guys posted - thanks !
