Lifespan of the stock battery
Stock KJ Battery is only 630 CCA (Amps)
Even though my stock KJ battery is a measly 630 amps, It must be good quality as load test states 712CCA. Will be 4 years old next May.
42120[/ATTACH]"]
IT is doing fine but when it fails a load test, Will Look for something in group 78/84 in 800 CCA+ to replace it with.
With temps now close to freezing, I Keep the KJ's stock battery plugged in overnight with an intelligent C-Tek charger.
42122[/ATTACH]"]
And 3 times a year pull the caps check electrolyte level and use hydrometer.
42124[/ATTACH]"]
After charging the reading is great.
Check each cell to see how they are doing!
For the V8 sedan with huge starter motor, in Feb I replaced the battery with a Dual Terminal group 78-84.
Some Batteries are over rated and not realistic. This is one that is rated 1050CA and (850CCA)
Even new fully charged this one did manage a load test reading 850CCA
It recently passed a load test at 810 CCA. (maybe it need more charging?) Has a bit more reserve as well.
Regardless of the numbers this battery will have more juice than a stock Chrysler Battery.
This battery also fits into KJ.
42126[/ATTACH]"]
ChiefRudy
Pittston, Pa
I'm still running the battery from the factory and I've had my jeep for 5 years as off last Friday.
JLRockies
Draper, UT
The stock Optima effed off in 2 years. The yellow top Optima I replaced it with effed off in 2 years. Optimas are a ticking timebomb of suk waiting to explode into a cloud of asstasm without warning.
My Odyssey PC1500 normally puts out over 1300cca's(880cca's rated),after playing movies with my stereo blasting for 4-5 hours with the engine off it still put out over 900cca's for a 3 year old battery.
BigRich201
west new york,nj
My factory battery finally died back in 09 so it was six years old. Now I have a duralast gold with 800 CCA.
My OEM battery lasted 5 years and then started cranking the engine slow and holding just under 12v when I replaced it.
BjBnet
Ottawa, Ontario, Canada
who cares how long they should last
I figure that they sure dont cost $100 to make so I try to get my $$$ worth
I buy Interstate bateries ,most small shops through out the country sell them
which makes warranty claims easy
Then when they are between 20 and 24 months ,their free replacement period
I leave the lights on
then bring the car to a shop tell them how I had to jump it to get it started
they will put in a new battery which will have a 24 month warranty from that day
I did this twice in the KJ and ,3 batteries, and once in the TJ
I will be getting another new battery for the TJ soon
and then you complain about the economy and factories going abroad :pp:
first&lastKJ
Indiana
I have had batteries go dead at the worst possible times. Most of the time they were over 6 years old. Now I just replace them every 4 or 5 years and I dont worry about it.
j-rod
Farmington, WV
wifes 05 KJ just got the battery replaced today. 6 years? holds charge but lost 200 CCA.
slapped a red top optima in today.....
bheiser
San Francisco, CA
I replaced the stock battery in my '06 a couple weeks ago. It was put in service in '05, so it lasted about 6 years.
jake1234
NY
I also got 6 years out of the mopar battery, never let it discharge or left my lights on tho.
AVR2
UAE
Where I live, you're lucky to get 12-18 months from a car battery, especially for anything with a large engine. In summer the temps routinely get up to 50C/122F for 3-4 months.
