Two different vehicles for sure. They both come factory with junky balljoints.
Well the solid front axle is certainly an advantage over IFS. I still wouldn't count the KJ out of the competition though...
I find it much more maneuverable. It's the perfect size, and handles are turns on the trail with ease.
I also have never driven a Wrangler. I feel like people who dis the Liberty for the Wrangler are basically just over compensating for the off roading that they DON'T do.
Actually that is not true,it hurts them more then anything and why most stretch there wheel bases to or a little longer then a KJ.. Also, a TJ will out maneuver a KJ any day. The shorter wheelbase is pretty advantageous there.
Way more people with Wrangler's wheel their vehicles than Liberty owners do. I have met very few KJ wheelers. Met hundreds and hundreds of CJ, YJ, TJ, and JK wheelers. Also, a TJ will out maneuver a KJ any day. The shorter wheelbase is pretty advantageous there.
Also explains why people like the Unlimiteds for wheeling much more. I found that the KJ has a near perfect stance for everything I've done.
Hey now! I never said I've met more KJ wheelers! I'm saying there's way too many people that don't do what the Wrangler is made to do![]()
And not to be a dik, but what you do in a KJ, pales in comparison to what can be done in a budget boosted Wrangler on 33's. I really dig my Libby, but am realistic with its limitations. I know there are better vehicles off-road. I don't see the need to constantly compare a KJ to Wrangler. Different vehicles.
I would bet you somewhere around 95% of Liberty's have never seen a trail. I bet that number is way less for Wranglers.
Don't take this as KJ hate. Just this comes up a lot, and isn't an apples to apples comparison. It is like an apples to zucchini comparison.
Try some trails out here,a stretched TJ makes doing shelfs/steps easier due to the longer wheelbase.Plus many like to do doublers and add D60's/14b's and gotta have a driveshaft longer then 6".Ever see a stock rear TJ driveshaft? It's about half the length of the KJ's.Gotta disagree on that. There is a reason why the wheelbase hasn't changed much in the past 40 whatever years of CJ's, YJ's, and TJ's. And maneuverability is a big factor of that. Ask any 4 door JK owner (aka school bus driver).Guys aren't stretching their rigs to maneuver better. It is due to stability more than anything. Gotta go longer if you plan to go bigger. And a stretched Wrangler is so far removed from a KJ that there is absolutely no discussion on the merits of one vs. the other.
So I read on another Jeep Owners forum that, "The Liberty can not be compared to a Wrangler." ... What do you guys think?
You're really just missing all of my points -___-
I know a Wrangler is much better. I know hardly and KJs wheel. I know Wrangler owners wheel more often. And I know the two don't compare...
Sheesh I would have bought a TJ if I could afford it. I couldn't, so I bought the KJ. And I'm VERY happy and EXTREMELY impressed with it.
The TJ or JK does not have a tighter turning raduis then a KJ or KK.The solid front axle limites turning raduis.LOL. Go back and read the other posts dude. What you are talking about isn't even relevant to the discussion. How does a stretched rig with Dana 60's and 14 bolts even get brought up in a KJ vs Wrangler discussion? What I stated earlier is true, a Wrangler with its shorter wheelbase and tighter turning radius will out maneuver, turn, steer a KJ. It just will. A SWB Wrangler will also have no problems on any obstacle that a KJ could make. I really don't even know what you are trying to get at at this point. :happy175:
I to have modded my KJ,like your TJ,and can push it as hard if not harder then your TJ without worry.Also most likely have a lower crawl ratio then your TJ since I have the better auto trans to start with.I've driven many modded TJ's and JK's and to tell you the truth they all rode like a$$,I've driven 8 wheeled drive wreckers(65 ton rated tow) with "G" rated tires that rode better then they did.I have owned and wheeled both
The TJ is by far better off road
The KJ is better on road
However you give up more to own a KJ
if you go off road
I have modded my TJ to ride better on road
and it also improved how it handles off road
and you can not push a KJ very hard
or risk exploding the front diff
nor can you gear it low enough to go slow
and compensate for the weak first gear in the trans
The KK has changed some of and with the addition
of 245/75 M/T's and a lift to fit them
4.56 gears and lockers front and rear and it would be
real close to hanging with a stock 2 door JK Rubi.
better than any stock 4 door JK and just as good
as a stock TJ Rubicon
All of which could easily be modded and thus giving them
The off road upper hand
I would and have considered selling my modded TJ
to buy a WK or KK to mod and some what replace
the TJ because I just don't wheel like I did a few
years back I just don't have $20k+ to buy the Jeep
and another $5k+ to mod it on day 1
Stock turning radius for a Wrangler(not unlimited) is about 41',stock turning radius for a Liberty is 35'.Fact #1 my TJ rides better than a stock TJ
I made sure of it (better than most)
Fact #2 my TJ even on 33" tall tires turned tighter
than a stock KJ
Fact #3 the trans in you KJ will not and can not work
with out a TCM to tell it what to do it has the same first
and reverse ratio as mine however my TF999 dates back
to the early '70's during the time of carburetors
it can be modified to run with no electronic input at all
and still handle V8 power easily
It will work at much steeper angles than your prized
45RFE thus making my TF 999 better suited for off road
Now behind the trans is not stock making your point
about crawl ratio point less
However my stock axles will handle 5:13 but for some
odd reason I ,nor any TJ with a 4.0 for that matter, would
not need any thing deeper than 4.88 to smoke 35's
Just another one of those odd things about wranglers
Because I know that the FJ owners have the same issues
they need 4.56's to pull 33's where TJ's do fine and are
happy with 4.10's
Go figure
Apples and Oranges.
I don't compare them. I like them both, but for me the KJ fills my needs better
