All good valid points...thank you. I am thinking I may go with the remove the whole din dam thing first time out so I can get any shavings from the break-in out ..the second time maybe just pump and fill.
How hard is it to replace the oil in the diffs? can I just pour some new oil in or should I pump out the old?
Awesome thanks....Do you really need to do it at every 30K on these Libs? My ****** Mechanic told me no...Easy, just did mine for a diff inspection. Took the whole cover off. Takes almost no time. Get a gasket at NAPA before you do the job. Bolts torque down to 30lbs. Gasket is easy to seal with a little Silicone. Should take no more than an hour with taking the cover off.
By the maintenance schedule in the owners manual the KJ's F/R diffs are to be serviced every 12,000miles.Awesome thanks....Do you really need to do it at every 30K on these Libs? My ****** Mechanic told me no...
After applying it to the diff, I let it sit for however long the instructions said on the package. I then tightened the bolts by hand and then by wrench until the RTV started oozing out a little. I let it sit for however long the instructions said and then torqued them down. I tightened and torqued them down in a cross pattern.Did you use a torque wrench or just ease it tight?
Schedule B should be followed when you...............Maintenance Service Schedule B calls for a front and rear drain and change every 12,000 miles if you use it for off road use, trailer towing, snow plowing or commercial use.
Maintenance Service Schedule A doesn't call for a drain and change that I can see on neither the front nor the back.
I am looking at a 2005 Owner's Manual.
I tow a trailer about three times a month or so, so I change them both every 30K with Mobil 1 75W-140. I don't think I use it enough to justify changing it every 12K.
However, after looking at the rear diff after the 30K mile change, I would definitely recommend doing it at least once every 30K miles.
I don't know about your's, but mine has a "asterisk" beside it and in the note it says to do it only if you "...(listed in my previous post)". That tells me that it is a break away from the normal Scheduled B Maintenance items and to only do it if those specific conditions apply.Schedule B should be followed when you...............
Drive day or night in temps below 32degrees
Stop and go driving(city driving)
Extensive idling
Driving in dusty conditions
One of those above certianly applies to every vehicle here.
