Just wondering if this is normal
TheBlueKJ
South Jersey
https://vimeo.com/169933561
Was just wondering if this type of movement is normal on the passenger CV. I've never tried moving it like that before but since I've been getting some vibes recently (which I thought I had narrowed down to u joints) figured I'd give the CVs a good shake down
Sent from my iPhone using the power of children's laughter
Video is darkened out with a message..
"Jeepers! This video can't be played with your current setup. whaaaat?
Can anyone else see it properly?
Of course my old video from photobucket on cv pas side does not seem to load at this time.
Will try video anyways:
[/URL]
If ya push on the sleeve/can you will get movement and sometimes a bit of a clunk.
Mine is fine like that as long as boot's not leaking it seems to be ok.
TheBlueKJ
South Jersey
That's odd, I posted it with my phone and it seemed to work there, I'm on my pc now and it still works for me. Anywho it's avid of me pushing up on the shaft vertically and getting movement up and down, not sure if it's normal intermediate shaft play or what
Jbergun
Chicago
Video works for me not sure if its normal i can check my in a bit just got home from work
turblediesel
memberable
Alaska
Worked on my phone which hardly works well at anything.
Seems like a lot of play to me. I haven't done anything to the driveline on my KJ except u-joints but it seems pretty clanky compared to other cv joints I worked on long ago.
Alec now that I've seen the video, yours is way loose, somethings up there.
You can easily push the whole thing up with just your thumb.
If you see my video by clicking on the image, I have to use mega force to even get mine to move slightly.
TheBlueKJ
South Jersey
So does anyone have any ideas what could cause that up and down movement?
JasonJ
Michigan
That does not look normal to me for a CV joint on ANY vehicle.
To me, that looks like a bad CV joint. It's likely come apart internally.
TheBlueKJ
South Jersey
Bad CV and/or bad half shaft. I would replace both (I did!)
It seems like its coming from inside there not the cv, so i guess it'd be the intermediate shaft. Hopefully nothing else is up in there
dude1116
Pompton Plains, NJ
Yes that's usually all it is. Although i think there is also an axle bearing in there you might want to replace while you're at it. I need to get in there and replace a seal so I might do the bearing too.
TheBlueKJ
South Jersey
The way it moves the bearing is probably wiped. How does a solid metal shaft go bad apart from the splines getting ripped off
That's pretty bad for play...even when new there might be a bit of slop there but no clunks or anything.
That's the shaft but check ebay, $134 seems a bit steep. I got mine for $110ish.
TheBlueKJ
South Jersey
Well looks like I got my next project planned out. I fix one thing and immediately after something else goes wrong. It's a vicious cycle
CactusJacked
Chicago Suburbs
The way she's flopping, suspect your intermediate shaft. Mine was moving bad like that, picture of it below. When the shaft end gets worn so badly, it acts like a wobble socket extension. Are you getting a clunking noise in front?
TheBlueKJ
South Jersey
Occasionally in tight turns I'll get one but i've always attributed that to the almost non existent steering rack bushings. other than that not really no clunks to speak of
TheBlueKJ
South Jersey
So after I installed the 4 link the vibes are all gone. Odd but hopefully they dont come back
TheBlueKJ
South Jersey
And they're back but only at highway speeds. I did actually do u joints last night since they were bad anyway, took it on the highway to see if that cured the vibes but it didn't so yea next month the halfshaft will be getting done
