just some advice on fluid changes
csharp84
lititz pa
My Libby has 76xxx miles on it. Its an 04 and this summer will be the first we will be towing with it. I have always done oil changes regularly but should I change the ****** and rear fluids? They have never been done before just wondering if I should do it now or wait till 100k...thanks
Daveos
Utah
Differentials are recommended at 36k. ****** Transfer Case are at 60K. I do mine every 30 - 40K. I would not wait until 100K to change the transmission and TC fluids.
Front and rear diffs are change every 12k-15k,trans fluid is every 30k,and t-case is 60k.ATF+4 only for trans and t-case.Plugs are every 30k with copper core plugs only.You are also due for coolant as your way past the 5 year mark,again HOAT coolant only for the cooling system.
Your way behind on maintenance.
