Just installed JBA 4" 350lb front struts
kjpilot
Minneapolis, MN
Ride is soooooo much better! I sit a little too high now by about 3/4 of an inch, which is about the height of a spacer that is located on the bottom of the spring... I just informed Marlin, but since it is 3AM in Pennsylvania, I probably won't hear much until tomorrow (um, later today I guess)
05kj6spd
Pennsylvania
did you get the reel cv axles or keep your stock ones? Also what size tire are you planning on running and do they require fender triming?
kjpilot
Minneapolis, MN
I got the JE Reels. The CV housing MUST be trimmed for this lift, modifying your own can be expensive. Talk to Marlin, He originally had a less expensive axle option with the trimming done in a machine shop.
I'm running 30" right now, & hope to be able to get 33", but I may be stuck at 32" max. I've bashed the pinch weld down, but don't know how much trimming will be necessary for 32-33"
