mercdudecbr600
- Joined
- Oct 3, 2018
- Messages
- 290
- Reaction score
- 71
Hi all. Just installed jba uca on my kj and found a few minor fitment issues that you all should be aware-of. The jba bushings are a little more than 1/8” wider than stock uca bushings and therefore you have much less wiggle room inside the frame mounting pocket. Jba manual say to expand the pockets but give no other instructions. I tried to fit mine as-is but it was too tight and no amount of hammering would make them seat properly. The bushings are 2” wide so… I cut a 2x4 to 2 1/8” by 18” and used a sledge to wedge them into the pockets and then levered the 2x4” over when fully seated. Gave JUST enough space to get the uca in fully. After putting lubricant on the bushings I was able to get them in.
By comparison to stock uca, These aren’t a snap to get in. Hope this helps someone else.
