JBA-IFS-KK build
For those not following along on fake book or over on LOST
Its out driving / testing now
Couple of pure jeep-sex pictures
BEFORE 4 inches of JBA lift and 32s and today
Counting My Blessings
Wow! That is a great color for a Jeep!!! :happy160:
Is that MountainMan's KK? Same color and the bumper looks right...
That's a lot of jack for a lift but if that's your purpose-built hobby/overland Jeep then why not. It's pretty awesome engineering for sure.
Love the design of the upper and lower a-arms. What gearing did he go with - 4.56's?
$20k for that?
Ah no thanks :happy175:
You're throwing out 20,000 and you have no clue what all parts there even is :happy175::happy175::happy175:
The ORI Struts are at least 800 each and there are 4 of them and thats only the beginning
( prices I found anyways for the length they used so right there is 3200 bucks)
No its not his, that guy is long gone
This belongs to Nathan from Texas
ATH front and rear bumpers
5.13 gears
9 inch ford front center diff etc
see below
4) ORI struts 14" long
Currie IFS center diff, Ford 9" with 5:13 gears
RCV custom CV axles
Howe Performance power steering pump, reservoir and cooler
Grand Cherokee (WK) parts
front bearing hubs
cut down steering knuckles
tie rod ends
Chevy suburban steering box & Idler arm
The rear
Dana 44 out of a JK with factory electric locker and 5:13 gears.
custom 3 link mount,
removed the fuel tank, muffler and exhaust system, rerouted complete exhaust.
The fuel tank is an modified fuel tank from an old Wrangler.
fuel tank is now where the spare tire was mounted from factory.
clocked the transfer case to center the front drive shaft.
Built a 10" cradle drop to hold the steering box and the Currie diff. The control arms are about 10" longer then the factory a-arms and mounted to the cradle.
Just a few of the things
Oh and when they were starting to mock up the rear
Can it play Crysis?
Sounds like quite an impressive overhaul. :waytogo:
OH YES, front has been moved forward 3 inches increasing the wheel base
noob question here.
Do extensive vehicle modifications like this require some sort of inspection?
Probably varies by state as well I take it?
noob question here.
Some states yes, I know here in Ohio, no one checks anything at all.
They used to do road checks on cars , stop you and look over your vehicle. Went through several with various builds on mine years ago and no one ever said a word. Don't do it anymore though. More likely than not they wanted to know more about the build.
Now some states though are really a**holes when it comes to builds like this
You could do something like this on a KJ right?
Yes even be easier in a way due to gas tank location, and exhaust
no relocating them , well slight mods to exhaust
Pretty much everything done here would go right on a KJ
Also pretty easy for Grand Cherokees as well
TheBlueKJ
South Jersey
Can it play Crysis?
I understood this reference :gr_grin:
Kinda makes me wish i didn't get rid of the jeep now that this is coming out
Staff online
