installing offroad lights, wiring help needed
Vranes17
New York
So i bought some 4x4 lights sticking them up by the mirrors by the windshield arm. How exactly do i hook this harness up?
I got the bottom set of black n white wires hooked up to the lights now where do the rest go?
J-Thompson
just south of doucheville
Red ,with fuse to battery +
Black on same end to battery -
the others to that switch
the black is a ground so the switch will light up
can not tell you about the switch but it will or should be labeled
just a side note
this is very basic DC wiring
if you find hooking these up difficult then you really should reconsider going
off roading ,and even more so at night which would require these lights
I was going to throw out using a relay off of the parking lights or running lights
so that when your lights are off then these lights will not work
Ry' N Jen
The first thing you should do is purchase a REAL wiring harness.
One (As J mention's) uses a relay so that you only have a very low amount of electrical power entering the cab of your "Car" :)D)
kb0nly
I don't buy harness's i build them custom... But anyway... LOL
Consult someone more experienced if you know anyone locally, electrical fires are nasty!
kjweston
Boca Raton, FL
For real.. bought one of those up above and ran my renny bar off it for like 3 minutes. started smoking.. had melted it together.. learned how and starting making my own harness's after that little scare..
J-Thompson
if you have a fire then you had no fuse or to much fuse
2 100W lights = 16.66A
so you need no more than a 20A fuse
problem with all this is can the switch handle a 20A load ,probably not
now if you have 2 55w lights then you are fine as that is less than 10A
I can not find my minimum wire awg chart I had but it showed the minimum
wire awg for a given current load
IMO that harness is probably maxed out at a 20A load
kb0nly
I don't even use a switch for a 10A load, always a relay and switch, but i'm picky like that. And i also wanted the lights to follow the headlight switch, off on high beam, on with low beam.. Etc..
hyde
is that some wires taped together with electrical tape?
speedracerbubba
It looks like heat shrink tubing so maybe it is soldered connections?
Sent from my PC36100 using Tapatalk
Porkchop
Troy Mi
I would wire them up using a relay if you dont know how get someone who knows how to do this.
Only my to cents but it will be more safe to do it that way
speedracerbubba
i got a cheap set of fog lights from walmart before and they had a relay which was nice and is good practice.
J-Thompson
I found the chart I was looking for
I am only posting up the gauge and current load
these numbers are "conservative"
wire - amp
AWG - load
12 - 9.3A
10 - 15A
8 - 24A
6 - 37A
4 - 60A
2 - 94A
1 - 119A
0 - 150A
Knowing A=W/V
then to run 2 55W lights you need at least 12awg wire
but 2 100W lights needs 8awg (considering a conservative #) you may be able to get away with #10 but why chance it?
use #16 to run a relay with #8 to power the lights
Vranes17
New York
thanks guys, took the lights to an audio shop after I decided I would rather my KJ blue and cool than bursting with flames. They installed a relay and mounted the switch for me.
Porkchop
Troy Mi
Sounds like a vary smart move if you dont know electrical wiring
What did it cost can we see pictures of the new lights
My dad wired his CB up north to come home I said I would do it for him when he got home but he didnt want to wait till he got home.
Long story short his new mini van went up in flames on the side of I75 over something as simple as a CB
Vranes17
New York
I get some glare on the hood right below the lights, but it looks cool from the inside so
