Sorry that I don't have any install kit pics but everything went smoothly except that when I installed the springs I did not line up the "key" for the clevis bracket correctly. I had to loosen the spring and rotate the strut assembly for the clevis to fit correctly. The Tie-rod and brake caliper did not need to come off to install the front shock/struts. I was going to use a clevis lift but the spring seat had a big gap which the conduit washers kinda fell into. The struts had a ridge under the spring seat that did not allow the clevis to go up against the seat...about an 1/8" from the bottom of the spring seat. The front shocks did not look like the yellow ones that were in the install pics that I have seen - they were white with the spring seats welded on the shock. The last rear spring was a bear to install even with the sway bar disconnected. It took me about 5 hrs with the spring mishap and I have never done it before. Looks goooood!
