Inner Rocker Panels
AJ9P
Wisconsin
Can anyone give me some good advice / pointers on how to remove the inner rockers of both side of my 2006 Liberty? I would realy like to avoid paying a body shop to do it. thanks
Just hangin' out.
Usually, when the cancer spreads to the inners on a unibody, this is bad news.
There are folks that have done repairs and replacements, but they have the gear and the skill.
Is an informative thread here:
If inners and outers are both bad about the only way to keep it alive is professional help or try boat siding it yourself which is still not a job for a beginner
CTJEEP
After market rockers are short on top + don't connect at the vertical pinch weld.
The inner rocker panels are sandwiched into the outer rocker + inner floor assembly. along with the connection of the Center pillar creating clearance issues.
What I've found are few KJ's with perfect rockers . . . Cut the donor section parallel to the rockers in about 12" in, the posts up 12" or so , and splice the assembly onto your Jeep.
Cheaper + faster than disassembly, cutting rot + refabricating adjoining rotted metal.
There are few if any OEM rockers + inners available . nice path, but the outer were over $700 when still available. .... and the end caps are long out of production.
