If you've got JBA UCAs and terraflex bumpstops...
LiberatorBB
Seattle, WA
...could someone take a picture of where they drilled into the bumpstops? I've got them on, I just can't make the beast flex enough to mark the spot to drill where that nipple hits the stop.
For the record I've got the frankenlift
4x4kayak2112
tx
Id remove the upper arm from the spindle and push them up and mark it.....that makes the most sense
Sent with the power of children's screams!!!
KJScott
East Central Florida
just cut a half inch notch on center, I used a band saw to make two cuts, then score it across the base of the cut using a knife on both sides, then pliers to tear out the cut. it will tear out nearly flat. Don't go crazy deep, you are just making a relief for the the zerk.
And snug up the zerk fitting, looks like it is weeping. Wise man Tom's good advice to me.
hardluck
Nova Scotia Canada
I just drove it , the nipple made a indent in the rubber , not a big deal , it wont break the nipple , its metal and the stop is rubber
Under the right conditions it could break the " nipple " actually a grease zerk , so cut and be good or not and cry when your "nipple" breaks .
There I said nipple twice in one post
hardluck
Nova Scotia Canada
Cry ? Probably not im canadian .. Lol ill just pick another one up for 10 cents .
LiberatorBB
Seattle, WA
It was really easy doing what KJScott said. Using a band saw and knife I just cut about a 1cm x 1cm x 1cm chunk out of the bottom.
JeepCoMJ
SE WI
Jo6pak
Left coast of WI
I once saw a stat that mentioned that 3% of the population has a 3rd nipple. Which means roughly 1 in 33 people.
So next time you are on a bus full of passengers, look around and see if anyone is rubbing themselves in a odd spot....
