I need help looking for a part
Strizay
I have an '03 3.7 and the vin is 1J4GL48K33W638449. I'm looking for the exhaust Y pipe. I don't know exactly what I'm looking for, but the mechanic said I have an exhaust leak between the pipe and the muffler and I need a new pipe. I found this one but he said he doesn't think it's right. Any help would be appreciated. Thank you guys.
blackhawk
Venezuela
Here you are.... This is for a 03 as per your vin number
DefCon2
Here is a link. You will want to view diagram #2. The Y pipe should be very evident to you.
Strizay
Yes, that's exactly what I'm looking for. Instead of paying over $2,000 for the pipe, I'm going to see if I can cut the third cat off and weld on a short straight pipe. I don't see why it would need or not function correctly with 2 cats. Thank you for your help. You are Extremely Appreciated.
Northern Idaho
You might consider a “cat-back” exhaust system which would just be a bolt on item. If you are getting holes rusted into the pipe you very likely have many more to come. Plus, if the pipe is shot having it welded to may not be an option as you need good steel/aluminum to weld to. Paying to have the system rebuilt one pipe/section at a time could cost a lot more that a pre fab kit and you will have your rig in the shop way more often.
Strizay
The mechanic said the exhaust leak was in the Y-pipe. he wasn't too specific. I'll know more Wednesday when I bring it in for other work. I can't see putting a $1200 system in a 22 year old vehicle. We just need to know where the leak is coming from and I'm hoping we can just cut off the bottom cat and run a staight pipe to the muffler.
Northern Idaho
I get it. Our 07 is paid for and we don’t intend on getting anything new. Too much $$$$$ so I don’t mind dropping one to three new car payments worth of new parts into it every year or so. Sounds like a patch it what you need!!
Strizay
In another thread I had the shift solenoid block replaced, came to a little over $500. And nothing changed, it's still doing the same exact thing, waste of money. Wednesday I'm getting the front drive shaft and front sway bar links replaced. Then in early July I'm getting new front brakes and rotors and rear shocks put on. I have a list. But like you said, I'd rather dump money into this Jeep then start over with something new.
Northern Idaho
It’s even more expensive having it done by a mechanic too. Lots of knowledgeable people on here more than happy to help with recommendations and advice on items that can easily be changed out by an owner with modest tools, AND most parts stores “rent” tools which is actually a “borrow” program cuz they refund the “rental fee” when the tool gets returned undamaged (and I always clean them and the case if it comes with one). I rebuilt my first carb on my Yamaha MX 100 when i was 12 and now at 58 I do all our automotive repairs on our rigs (07 Lib-Sport; 2015 Explorer Sport and 02 Outback H-6). Stay on here the folks here are GREAT and always willing to help out!! Full disclosure though, I suck at electrical stuff!!!! I hate it with a passion!!!! It is definitely my kryptonite……
Strizay
I'm unable to do my own work now due to health issues. I can't even change my own oil. And finding someone to help me around where I live is almost impossible. I asked a guy how much he would want to change out my transfer case fluid. I have everything he needs, all he has to do is is crawl under there and drain / refill. He wanted $30.
